bcuziwasbored
Apr 08, 2020Aspirant
Nighthawk® AX12 RAX120 5GHz Issues
I just got the RAX120, but when I went to set it up, I found that I can't see the 5GHz band from any of my devices. I have multiple devices which support WiFi 6, but they can't see it either. I've ch...
- Apr 10, 2020Amazon Warehouse got another unit last night. I'm just going to get a replacement. Thanks for your help though!
Shelby500GT_x
Apr 10, 2020Tutor
Hey bcuziwasbored,
Check what you have enable at the top of wireless setting.
Also, I don't have a mode of 4333.
If you can I will conpare my setting with yours but you need to tell all of them which could be pain full. If you can tell my all of the Wireless ones.
Shelby500GT.
- bcuziwasboredApr 10, 2020AspirantAmazon Warehouse got another unit last night. I'm just going to get a replacement. Thanks for your help though!
