bcuziwasbored
Apr 08, 2020Aspirant
Nighthawk® AX12 RAX120 5GHz Issues
I just got the RAX120, but when I went to set it up, I found that I can't see the 5GHz band from any of my devices. I have multiple devices which support WiFi 6, but they can't see it either. I've ch...
- Apr 10, 2020Amazon Warehouse got another unit last night. I'm just going to get a replacement. Thanks for your help though!
Shelby500GT_x
Apr 10, 2020Tutor
Hey bcuziwasbored,
Check what you have enable at the top of wireless setting.
Also, I don't have a mode of 4333.
If you can I will conpare my setting with yours but you need to tell all of them which could be pain full. If you can tell my all of the Wireless ones.
Shelby500GT.
bcuziwasbored
Apr 10, 2020Aspirant
