Tes_Crys_Noice
Jan 16, 2022Aspirant
Nighthawk® AX4 4G LTE Modem + WiFi 6 Router SIM Compatibility
Hello! I have a question related to the Nighthawk AX4 4G LTE Modem WiFi 6 Router: https://www.netgear.com/home/mobile-wifi/routers/lax20/ It says in the SIM compatibility thing that has some certifi...
Tes_Crys_Noice
This one from Amazon to be more exactly:https://www.amazon.com/NETGEAR-Nighthawk-4-Stream-Router-Built/dp/B08NXXJL1F/ref=sr_1_7?keywords=netgear+lte&qid=1642352135&sr=8-7
DarrenM
Jan 19, 2022Sr. NETGEAR Moderator
This is LTE router for North America. You can find a unlocked one here https://www.netgear.com/uk/home/mobile-wifi/routers/lax20/
- Tes_Crys_NoiceJan 19, 2022AspirantOk, this one will work with all cellular data peoviders from every country. Thanks for help.
