jpamix's avatar
jpamix
Nighthawk® X10 Smart WiFi Router and NIGHTHAWK TRI-BAND AX12 12-STREAM WIFI 6 ROUTER Model: RAX200 ?
Good morning, I liked a bad opinion of the community in relation, I am thinking of buying a netgear router but I would like to know your choice between Nighthawk® X10 Smart WiFi Router and NIGHTHAWK ...
  • Christian_R's avatar
    Jan 16, 2020
    HI jpamix,
    Both routers are great! Key difference between the two routers is that the RAX200 supports WiFi 6 and the the R9000 does not. If you have devices that support WiFi 6, you may want to check out the RAX200.
    Christian
