meill
Nov 16, 2024Aspirant
Nighthawk - can't connect locally router
I have an RAX45 and can no longer connect locally. I can only connect via Anywhere Access. Any tips on how to fix would be greatly appreciated.
Bit thin on details.
Is this the Nighthawk App?
You are connected to the local wifi?
Is this Android or iOS?
Which firmware on the RAX45?
Just another user with time on their hands.
and what modem/gateway is the router connected to? double nats are great at causing that issue
