hbat
Jun 26, 2022Aspirant
Nighthawk - wifi mesh compatible?
ive got the Nighthawk AX8 AX6000, and live in apartment with brick walls. suffering with many dead spots for wifi. If i buy a couple mesh wifi extenders will it work with this router ?
michaelkenward
Jun 27, 2022Guru - Experienced User
hbat wrote:
ive got the Nighthawk AX8 AX6000....
Which one? AX6000 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number. Something like RAX80 or RAX120.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware.
Depending on the actual model number that's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
