W8NEE's avatar
W8NEE
Follower
Apr 07, 2022
Nighthawk 12212021
I am a Radio Amateur and using the internet for transmit/receive via wifi using Digital Mobile Radio. Is there a security block of some sort to prevent signals from passing? My signals get to the  Nighthawk satellite and no further, I also hear no incoming. I have no trouble with other VOIP connections.
1 Reply
  • FURRYe38's avatar
    You gave us nothing to go off.
    What Nighthawk product model are you referencing?
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
