Ksnyder
Apr 22, 2020Aspirant
Nighthawk 5400
Replaced a linksys router with a 5400 and can’t get Dell laptop to see either band as an option. Kept name and password the same as linksys. Everything else in the house connected fine.
- Apr 23, 2020
Coop102072 wrote:Would be helpful if you shared what he unchecked as I am having the same issue with my Lenovo and Hp laptops....every other device is fine.
Thanks
I have a feeling he unchecked "enable ax".
many laptops with intel chips have issues. Reason why is people rely on the manufacturer (lenovo/hp) or windows update to update the drivers. And they don't.
If you go to the chip manufacturer website of your wireless card, many times theres newer drivers that have fixed many issues with AX devices.
Ksnyder
Nighthawk AX6 6-Stream AX5400 WiFi Router(RAX50S)
Ksnyder
My younger brother (IT guru) came over and logged into the router webpage and there was a setting box checked (not sure which one) but he had never seen it before, unchecked it and was able to connect without any problem after that.
Thanks for any/all of your time!!
Kraig
- Coop102072Apr 22, 2020Aspirant
Thanks
- plemansApr 23, 2020Guru - Experienced User
Thanks
- Coop102072Apr 23, 2020Aspirant
Thanks! I started fiddling around before your answer and yes, that did the trick. Thanks so much.
plemans wrote:I have a feeling he unchecked "enable ax".
- KsnyderApr 23, 2020Aspirant
Ya.........sorry........I was at work and my wife said, "I don't know, he just unchecked something and it worked"!!
I hadn't had a chance to reach out to him.....
Glad we are both up and running!
K
Just an FYI, it does disable wireless AX.
I'd try updating the wireless chip driver in those computers. And then try re-enabling wireless AX.
if it works, great! If it doesn't, you can always uncheck it until the manufacturer updates the wireless driver.
