Ksnyder
Apr 22, 2020Aspirant
Nighthawk 5400
Replaced a linksys router with a 5400 and can’t get Dell laptop to see either band as an option. Kept name and password the same as linksys. Everything else in the house connected fine.
- Apr 23, 2020
Coop102072 wrote:Would be helpful if you shared what he unchecked as I am having the same issue with my Lenovo and Hp laptops....every other device is fine.
Thanks
I have a feeling he unchecked "enable ax".
many laptops with intel chips have issues. Reason why is people rely on the manufacturer (lenovo/hp) or windows update to update the drivers. And they don't.
If you go to the chip manufacturer website of your wireless card, many times theres newer drivers that have fixed many issues with AX devices.
Coop102072
Thanks
Apr 23, 2020Guru - Experienced User
Thanks
- Coop102072Apr 23, 2020Aspirant
Thanks! I started fiddling around before your answer and yes, that did the trick. Thanks so much.
plemans wrote:I have a feeling he unchecked "enable ax".
