Lach
May 16, 2020Aspirant
Nighthawk A12 don't detect the HDD attach to the USB port
Hello. I have a small problem with my Nighthawk A12 or RAx 120. Everything was fine until today I try to access to my files with my app ReadyCloud ( the same problem occurred when I use and web page r...
- May 22, 2020
Hi Lach,
May you try reverting to the previous firmware version and letting us know if there are any improvements.
https://kb.netgear.com/000061718/RAX120-Firmware-Version-1-0-1-118-Hot-Fix
Christian
Christian_R
May 20, 2020NETGEAR Employee Retired
Hello Lach,
What firmware version is your router currently on? Have you had a chance to reboot the router?
Christian
- LachMay 21, 2020AspirantHi. I update it with the last firmware 1.0.1.122. I restart the router but is the same. I think the last firmware causes the problem. The app and website readycloud doesn't detect the hdd attach to the router. Thanks
- LachMay 21, 2020AspirantWhen I go to the website and click on the router show No volume or USB disks
- Christian_RMay 22, 2020NETGEAR Employee Retired
Hi Lach,
Christian
- LachMay 22, 2020AspirantOk. I will. Thanks
