kdsturg5370
Mar 14, 2024Aspirant
Nighthawk AK6 AX5400 6-Stream Power LED Blinking Blue Rapidly
The power went out on my home Nighthawk AK6 AX5400 6-Stream Router and when power came back up the power LED Started blinking blue rapidly. The light comes on right away with no amber light before it...
Mar 14, 2024Guru - Experienced User
With the router disconnected from the modem and all other devices, what happens if you press the reset button for 15 seconds then release? Give about 1 minute then see if you can connect to the routers web page with a wired PC at 192.168.1.1?
What model RAX is this router?
kdsturg5370
Yes I have tried the factory reset a few times with no luck.
