kdsturg5370
Mar 14, 2024Aspirant
Nighthawk AK6 AX5400 6-Stream Power LED Blinking Blue Rapidly
The power went out on my home Nighthawk AK6 AX5400 6-Stream Router and when power came back up the power LED Started blinking blue rapidly. The light comes on right away with no amber light before it...
kdsturg5370
This is an RAX 50 v2
Mar 14, 2024Guru - Experienced User
Ok. Last resort is a 30-30-30 reset with nothing connected to the router.
- kdsturg5370Mar 14, 2024Aspirant
Ok tried that but can't get passed the light blinking. It doesn't react at all when I press the reset button. Am I just out of luck?
- FURRYe38Mar 14, 2024Guru - Experienced User
Seems like it. If you can't get the top LEDs to come ON or access the routers web page after, contact NG support to see what your options are:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
Good Luck.
