AdieMonk
Jan 24, 2021Follower
Nighthawk and smart pseaker issues
Hi I've recently installed a Nighthawk MK63 Wireless Mesh Wifi6 system, which has seen a massive improvement in performance over my old system. I have a total of 35 devices connected across the ...
Jan 25, 2021Guru - Experienced User
What modem/gateway do you have?
What firmware is on the MK62/3 system?
- BPearceFeb 04, 2021Guide
I am experiencing a similar issue with a new purchase of a MR60 with two satellites that are hardwired to switch. Airplay is not functioning well if at all with HomePod or HomePod mini, other Airplay devices seem to appear then disappear in list. Otherwise the system seems to be performing fairly well, great speeds but I'm not willing to sacrifice sketchy AirPlay performance
I have the latest firmware as of February 5, 2021(v1.0.6.110). Shaw ISP uses Arris XB6 I believe as the modem (I have it in bridge mode)
