pbharrison
Jun 22, 2020Tutor
Nighthawk Android app cannot connect to RAX45 configured as AP
The Nighthawk Android app fails to connect to my AX6 RAX45 Nighthawk router. I have it set as an access point for wifi. My cable modem is doing the routing and assigns a specific IP address to the ...
pbharrison
Jun 22, 2020Tutor
Yes, it works fine from the browser login to the router home page. But I would like the convenience of using the Android app.
pbharrison
Jun 23, 2020Tutor
On my 3rd contact with support, I was told that the Nighthawk app does not work with the router in access point mode. Disappointing.
