VP2k
Aug 01, 2019Follower
Nighthawk App (Android)
The Nighthawk App version V2.4.1.721 for Android on AX120 lacks Parental Controls and Network Map features. Ony have the following features on my device. Device manager, Internet speed, Wifi Ana...
schumaku
Aug 01, 2019Guru - Experienced User
VP2k wrote:The Nighthawk App version V2.4.1.721 for Android on AX120 lacks Parental Controls and Network Map features.
None of the Nighthawk AX routers does currently support parental controls (neither the legacy Live Parental Control [OpenDNS based] nor the "current" Circle offering).
While some YouTube marketing blush showed a network map, there isn't one [certainly not for many Nighthawk router models].
VP2k wrote:Ony have the following features on my device. Device manager, Internet speed, Wifi Analytics, WifFi Settings, Guest WiFi and Traffic Meter.
That's correct and reflects the features available on the current AX router model line. None of the Nighthawk AX routers does currently support parental controls (neither the legacy Live Parental Control [OpenDNS based] nor the "current" Circle offering).
Where have you spotted that the Nighthawk App on the tri-band AX12 is supposed to support a network map and parental controls?
