Cyberpunk84404
Jun 12, 2021Aspirant
Nighthawk App iOS 2.10.0.16 Logon timed out, please try again.
I have a new Nighthawk RAXE500 Firmware Version V1.0.5.62_2.0.35. I'm using an iPhone 12 pro iOS 14.6 with Nighthawk app version 2.10.0.16. I can access the routers web config using my PC. When I t...
Cyberpunk84404
Jun 13, 2021Aspirant
Thanks - my PC is plugged into the router with a network cable and I access the routers web interface from there. I’m unable to enable anywhere access as that can only be enabled via the app, which won’t allow me to log into my router.
michaelkenward
Jun 13, 2021Guru - Experienced User
Your first message referred to using the iOS 14.6 with Nighthawk app. That is not the same thing as a network cable on a PC.
If you want to access the RAXE500 with the Nighthawk app, then you need to connect using the wifi from the router.
If you want to use an iOS device on a browser, an alternative is to use the browser on the mobile device, not the app. Use the same address that you use with the PC.
You should also be able to do that on a browser.
