orionkhan's avatar
orionkhan
Nighthawk app not listing or showing connected devices AX6 6-Stream AX5400 router
I have a Nighthawk AX6 6-Stream AX5400 WiFi Router(RAX50S). Recently the Nighthawk app (Android 11)has no longer been showing connected devices. Shows 0 devices connected. I use the parental controls...
  • orionkhan's avatar
    orionkhan
    Jul 13, 2021
    Thanks for the info. As it turns out, I ended up doing a factory reset of the router and that fixed the issue. While doing the reset, I also reinstalled the nighthawk app. Seems to be working normal again.
