OsoLuv
Feb 06, 2022Aspirant
Nighthawk Armor detected & blocked exploit an exploit attack on LT SECURITY camera from.....
Hello, Hoping someone can help me understand the multiple notifications I get on a daily basis from Netgear Armor Security running on my router. Network Attack Blocked: NETGEAR Armor has detected a...
Razor512
Feb 07, 2022Prodigy
If you have a security camera that is directly accessible from the WAN (e.g., someone tiping in your WAN IP address, will see a login page for your camera, then it will frequently be scanned by various bots, including ones that feed into searchengines such as shodan, where if you have a default password, the camera willbe effectively added into a wall of shame like directory.
Other groups will simply have bots do discionary attacks on any server they find while continuously scanning the IPv4 address space. There is not much that can be done about them since it happens in every country, and through the nature of bots, as well as other infected systems, the device launching the attack, may simply be someone who clicked on a malicious ad and got their system infected, and now their PC is part of a bot network being used to attack others.
Netgear Armor will block behavior such as that, e.g., if someoneis trying to do a dictionary attack, but really, such devices should not be set to have a web UI visible via your WAN IP address, instead, you should be using the VPN server in the router to access the device.
To test, if the web UI for your cameras are exposed on the WAN side, try using a smartphone, that is connected to LTE and not WiFi, then type in the WAN IP address of your home connection, and see if it brings up the web UI or a login page of any device on your LAN (try both http and https).
If the device does not offer a simple way to prevent such access, then use the service blocking function in the RAXE500's web UI to disable access to those ports that the web UI is hosted on.
OsoLuv
Feb 07, 2022Aspirant
Hello Razor512 ,
Appreciate you answering and shedding some info on my situation.
I only access my security camera network via it's app (LTS Connect) installed on my iPhone. But after reading your response I confirmed it's accessible via its external IP address (Web UI) and a login page for the camera NVR ( I am not using a default PW ) comes up. I guess that explains the constant notifications from Netgear Armor stating threats were blocked.
Do these bots only target security cameras? Should I be concerned with other devices within my home network? (Ring Doorbell, Nest Cams?)
Would you kindly help me understand how to set the Web UI not to be visible via my WAN IP address and how to leverage the routers VPN to access my cameras? or how to use the service blocking function of the RAXE500's we UI to disable access to those ports that the web UI is hosted on?
My apologies in advance for the naive questions.
Thank you
