w4wws
Dec 08, 2020Aspirant
Nighthawk Armor security- Nighthawk RAX120
Since I purchased the Armor security for my router it has locked out a device on my newtork. The device is a PI-STAR which i use for ham radio, so how can i get it unblocked to i can use the PI-Star ...
Christian_R
Dec 15, 2020NETGEAR Employee Retired
Hi w4wws,
Can you confirm that when you disable Armor you're able to access your device?
Christian
w4wws
Dec 15, 2020Aspirant
No it still seems that it will not get to the world wide web. it worked before the armor was put on.
