klsheridan16
Aug 03, 2023Aspirant
Nighthawk AS2400 RAX30
My router randomly stops communicating/connecting to the internet.
Specifically, the 2nd light from the top goes out. I can access the router and it tells me it cannot connect to the internet. Says to check that the cable is connected. That's not the problem. I take the cable out of the router and plug it directly into my laptop and the laptop connects to the internet.
I've tried turning it off for a while. Sometimes when it comes up it works and sometimes it doesn't. There doesn't appear to be a common theme to when this happens. I've had the router for right at a year. This started happening about 3 months ago. It will go weeks and be fine. Came in yesterday morning for work, no light. Turned it off all day and plugged directly into my laptop for work. After work, turned it back on and nothing.
We have another Nighthawk router in another part of the house. It hasn't done this. Its on and working while this one says it cannot connect. Clearly, since I can take the cable and plug it directly into the laptop, its not the cable.
Any ideas?
Thanks!
- KitsapMaster
klsheridan16 wrote:My router randomly stops communicating/connecting to the internet.
Any ideas?
Thanks!
Additional details about the devices and connection layout of your local network would be very helpful.
What is the brand name and model number of the modem/ONT you use to connect to the internet?
You mention another router. What is the brand name and model number? How is it connected into your network?
- klsheridan16Aspirant
AT&T is our ISP. Hard wired into a Nighthawk AX5 AX4200 Model: RAX43 (living room). Hard wired into this router AS2400 RAX30 (office).
Works as expected 90% of the time. Then stops working and says the cable isn't connected.
- KitsapMaster
klsheridan16 wrote:AT&T is our ISP. Hard wired into a Nighthawk AX5 AX4200 Model: RAX43 (living room). Hard wired into this router AS2400 RAX30 (office).
Repeat question: What is the brand name and model number of the modem/ONT you use to connect to AT&T? Look on the label if you need to.
You are fortunate it works 90% of the time. Your configuration has a router connected downstream of another router. The two devices are constantly fighting over control of your network. This configuration is known as double NAT and it is not good. For reference, see this Netgear article:
https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
The easiest option is to configure your downstream router (RAX30) as a wired access point. Go to the Downloads section at the top of this page, feed in your router model number (RAX30) and download the users manual. Details on configuring your router as an access point start on page 70.
Most likely it will not be an issue, but be aware some features on your RAX30 will no longer be available when it is configured as an access point. The features disabled on your RAX30 are still available on your RAX43. See Netgear article here:
When you are configuring your RAX30, make sure you are connected to the user interface for the RAX30 and not to your RAX43.
