Spakls103
Oct 13, 2020Follower
Nighthawk aX 12 12 stream try being a X Wi-Fi router
I keep trying to do the new firmware update had to router for just under a year have three weeks for my warranty left it find my router download it it says it's updating but just sits there and spi...
Oct 13, 2020Guru - Experienced User
Is this for the RAX router series? If so, then you need to post over in the RAX router forum:
Good Luck.
