Spakls103
Oct 13, 2020Follower
Nighthawk aX 12 12 stream try being a X Wi-Fi router
I keep trying to do the new firmware update had to router for just under a year have three weeks for my warranty left it find my router download it it says it's updating but just sits there and spi...
Christian_R
Oct 14, 2020NETGEAR Employee Retired
Hi Spakls103,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
