iamken
Apr 25, 2020Aspirant
Nighthawk AX 12
Hi. Just got this router today. Ordered it from Amazon. Set up was easy it did a firmware update during the initial install but I've been having problems keeping the connection. One of my laptops wont...
Bogbird
Try increasing the keep alive.
- iamkenApr 25, 2020AspirantTy for replying. I'm sorry but I'm a noob so I dunno what that means. I just rebooted the router via the nighthawk app and I still have no net on my desktop and only 5g connects on phone
- dglsmcd_USMCApr 26, 2020Luminary
Do a hard reset (with router powered on press and hold the reset button on the back of the router for at least 10 sec). Using the Nighthawk app setup your router from scratch, DO NOT use a previous config file to setup your router. Make sure using the GUI from a wired connection to the router that all your devices are reflected on the attached devices. Also, go to the Advanced tab and under Administration update the NTP settings to correctly reflect your time zone information. Make sure that you click on the apply button and reboot the router after every change using the GUI. Depending on your operating system, get a good wifi analyzer app/program that will show you the status of your wifi connection(s) and if there are any conflicts (same channel usage) from surrounding neighbors-this might neccessitate changing the radio channel. I recommend using a hard channel vice letting the router use auto mode for channel selection ensure deconfliction with nearby radios.
