RJK1000
May 16, 2020Tutor
Nighthawk AX11000 (RAX200) disable 5ghz radio only?
Nighthawk AX11000 (RAX200) disable 5ghz radio only? Considering purchasing a AX11000. I looked at the user manual and it describes how to turn off the radios. It does not specify if I can turn off ...
- May 17, 2020
Sorry you can't, it's all or nothing. see attached screen shot
Considering purchasing a AX11000. I looked at the user manual and it describes how to turn off the radios. It does not specify if I can turn off the 5ghz and the 2.4ghz radios separately.
Can anyone confirm that I can turn off the 5ghz radios and leave the 2.4ghz radios enabled? Or, if it is an all or nothing situation?
If anyone could post a screen shot of that setting I would appreciate it!
Thanks!
RajaDaja
May 17, 2020Luminary
Thanks!
RajaDaja
Sorry the info I provided is incorrect.
Thanks!
