Eric35
Dec 21, 2021Guide
Nighthawk AX11000 Schedule 0ff/0n ?
Hi. Is there a Schedule 0ff/0n to make the Router power off at exact time at night and wake up automaticaly at some schedule time ? I remember few years ago a netgear router had it, what about rax...
Dec 21, 2021Guru - Experienced User
As far as I'm aware, that was only wireless schedule on/off.
https://kb.netgear.com/24102/How-do-I-set-up-the-wireless-schedule-on-my-Nighthawk-router
Eric35
Dec 21, 2021Guide
Well in my older netgear router there was Schedule 0ff/0n, not wireless but turning router 0ff/0n...
- FURRYe38Dec 22, 2021Guru - Experienced User
NG routers have scheduling for wifi radios to be ON or OFF. Never have seen a funtion to turn OFF and back ON of the entire router system. Intended designe of most routers is to be ON 24/7 to provide internet access all the time. IF you need something to turn OFF and ON your router, might review a power timer device that can do this for you.
- Eric35Dec 22, 2021GuidePower time will harm your router in the future.
It is a good suggestion but not a good choice for the future!!!
