thelightfoots
Dec 29, 2022Aspirant
Nighthawk AX12 12-stream AX6000
After installing a new Nighthawk Modem and Nighthawk AX12 12-stream AX 6000 router, I am having difficulty with my Fire Stick. The logon sheet shows the TV is connected to the wi-fi, but there is no...
- Dec 30, 2022
What actual device do you have? AX6000 is a speed, not a model.
What modem/gateway is the router connected to?
thelightfoots
Dec 30, 2022Aspirant
I have resolved the issue after a series of boots and reboots of the modem, router, and TV. Everything is working fine now. Thanks for your interest, and Happy New Year from Texas.
Dec 30, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
