corockclimber
Oct 20, 2022Aspirant
Nighthawk AX12 AX6000 max LAN speed
I have Xfinity Gigabit Extra plan at 1.2Gbps cable inter hooked up to a Nighthawk 2.5Gbps Cable Modem (CM2000). My computer has a Realtek Gaming 2.5GbE Family Controller and I am using Cat 7 ethernet...
Oct 20, 2022Guru - Experienced User
Something isn't reading right with your setup if you're reading 3gig up. As the CM2000 and xfinity don't support those speeds on the upload.
to start off with, don't trust the built in speedtest at multigig speeds. It rarely will max them out. I'd recommend using xfinity's speedtest as that's been the most accurate for me on xfinity.
The other thing is you won't see multigig speeds over the wired because it only has the 1 multigig port and you're using that for the wan port. What I usually tell people to do is run 2x wired speedtests at the same time. (if you have 2 wired computers). Or even just run 1 wired and wireless test. And again, test on xfinity's site.
corockclimber
Oct 23, 2022Aspirant
Sorry, that was a typo......should be Mbps and not Gbps.
