Pat_Sull
Nov 01, 2021Follower
Nighthawk AX12 Fan not working
Is anyone else havinbg issues with the fan not working in the router? I have already sent one back and the replacement seems to have the same issue.
Eric35
Dec 21, 2021Guide
So how to fix this issue?
And where the h*** is netgear support here?
I never see them posting anything in here.
Dec 21, 2021Guru - Experienced User
What issue are you having?
- Eric35Dec 21, 2021GuideFurrye38> Buffering issue on streaming and heat/warm router at my home...
So how to exactly fix those 2 issue ?- FURRYe38Dec 21, 2021Guru - Experienced User
Please make a new post about the buffering issue.
Alternative solution would be to put a USB Laptop FAN under the router. I keep one under any router I have online.
