DBAM68
Sep 10, 2020Aspirant
Nighthawk AX12 Printer wont connect
Trying to connect my Xerox Phaser7100 to me new Router. Physical connection via Cat6 cables from printer to port5 on the router, Amber light flickering. Run set up wizard, "printer not detected", tried printing "Printer off Line"
Printer had worked previously via physical connection (same Cat6 cable) to Virgin router, which I have set to Modem mode and with Cat6 cable to Port 1 on my AX12.
With very limited knowledge, assitance would be appreciated
1 Reply
- Christian_RNETGEAR Employee Retired
Hi DBAM68,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
