Th3-0n3
Jan 07, 2021Tutor
Nighthawk ax12 rax 120 keeps disconnecting from internet after updating. any help?
Hello every one I have this problem with my Nighthawk ax12 rax 120. out of nowhere it updated by it self even those I had desible updates. Now version of the router is v1.2.0.16. I remember that befo...
Christian_R
Jan 12, 2021NETGEAR Employee Retired
Hello,
You may factory reset your router and run through the setup assistance again. You may also revert to the previous firmware version manually.
Christian
