Th3-0n3
Jan 07, 2021Tutor
Nighthawk ax12 rax 120 keeps disconnecting from internet after updating. any help?
Hello every one I have this problem with my Nighthawk ax12 rax 120. out of nowhere it updated by it self even those I had desible updates. Now version of the router is v1.2.0.16. I remember that befo...
Tofu-Golem
Mar 09, 2021Apprentice
Is it possible your router has the wrong time, or a different time from your mobile devices?
- AutomoIT-CTOMar 10, 2021Aspirant
Time was correct but Time Zone was set for Arizona and not Mountain.
I've corrected this but can't imagine it'll make much difference since the actual time was correct. - Th3-0n3Mar 10, 2021TutorHow do I check the time on the router?
But I think it has the correct time.
Where in the settings can i check this
