Th3-0n3
Jan 07, 2021Tutor
Nighthawk ax12 rax 120 keeps disconnecting from internet after updating. any help?
Hello every one I have this problem with my Nighthawk ax12 rax 120. out of nowhere it updated by it self even those I had desible updates. Now version of the router is v1.2.0.16. I remember that befo...
AutomoIT-CTO
Mar 09, 2021Aspirant
Surely there is a better answer than "Restore to Factory and Run Setup Again". A simple google search shows that this exact issue has plagued Netgear routers for years. I'd think it'd be resolved by now.
Is there a box that we're missing or a config tweak that'll resolve this? I'm now working on the 2nd unit from Amazon with the same issue.
The latest firmware is installed, pretty generic setup. Nothing special configured yet, knowing I might have to wipe it/start over...
Any help will be greatly appreciated!
Router: RAX120
Firmware: V1.2.0.16
ISP: Comcast Gig
Th3-0n3
Mar 10, 2021Tutor
Hello I'm having this problem more often with the latest firmware. I have been having this issue since the router release. But now it happens more then 3 times a week and some days 2 or 3 times a day where I have to reboot the router to get the 5 ghz band to work again, and get faster speed on the 2.4 ghz . I had an old firmware where this problem would occur at least 1 a month but the router updated automatically even thoe I had it set to not auto update. At this point I haven gave up on the router and for now the brand. I'm looking for a better router from another company because this issue doesnt get solve.
