Th3-0n3
Jan 07, 2021Tutor
Nighthawk ax12 rax 120 keeps disconnecting from internet after updating. any help?
Hello every one I have this problem with my Nighthawk ax12 rax 120. out of nowhere it updated by it self even those I had desible updates. Now version of the router is v1.2.0.16. I remember that befo...
Tofu-Golem
Mar 09, 2021Apprentice
Is it possible your router has the wrong time, or a different time from your mobile devices?
Th3-0n3
Mar 10, 2021Tutor
How do I check the time on the router?
But I think it has the correct time.
Where in the settings can i check this
