SkieStrife
Aug 19, 2019Aspirant
Nighthawk AX12 RAX120 Drops Internet When PS4 Goes Online via Ethernet
Can someone explain to me why this $400 router suddenly drops its WAN shortly after my PS4 Pro connects to the internet via Ethernet? EVERY device thats attached to the router will suddenly lose its ...
Rayant4
Aug 23, 2019Aspirant
Mine doesn't disconnect but I'm getting major lag spikes, same thing happened with the x6 r8000
- Christian_RAug 26, 2019NETGEAR Employee Retired
This may sound silly, but have you tried switching out the ethernet cable that is connected to the PS4 and router.
~Christian- Snipe263Aug 26, 2019AspirantI had the same issue as OP. As soon as I turned on my PS4(5ghz) all other WiFi clients stopped working. Downgrading router firmware fixed it. I just manually uploaded the new firmware and then reset the router. So far so good and I disabled auto update.
- SkieStrifeAug 28, 2019Aspirant
Snipe263 wrote:
I had the same issue as OP. As soon as I turned on my PS4(5ghz) all other WiFi clients stopped working. Downgrading router firmware fixed it. I just manually uploaded the new firmware and then reset the router. So far so good and I disabled auto update.Haven't tried downgrading to a previous firmware yet. I'll give that a shot when I can.
Tried it with several new ethernet cables, including removing my UPS from the equation. WAN from the cable modem connected directly to the router WAN port. When the PS4 is powered on via ethernet, the WAN will drop either immediately or within 15 minutes on average. I also had a strange situation the other day where the PS4 stayed online, but every other ethernet connected device dropped (PC & Nintendo Switch). Again, the situation wouldn't resolve until after the router was rebooted.
Keeping the PS4 on the guest 5Ghz Wifi seems to reduce the occurance of WAN lockout, but I'm also keeping the PS4 off when its not in use and no longer using its Standby feature because I fear the WAN will drop randomly when I'm gaming on the PC or downloading things.
- Rayant4Aug 28, 2019AspirantI switched ethernet cords and all is well
Every now and then mine will do the same thing as well. I thought it might've been my VPN (ProtonVPN), but it happens at random regardless of whether not the VPN is active.
