RMDEQ
Jul 05, 2020Star
Nighthawk AX12 RAX120 Link Aggregation Error: Unable to establish WAN aggregation. V1.0.1.122
I recently bought a CM1150V and a Nighthawk AX12 RAX120. The Nighthawk AX12 RAX120 always gives me the message "Error: Unable to establish WAN aggregation." I don't think the error is in the CM11...
RMDEQ
Jul 06, 2020Star
Solved.
To do link aggregation with two ports, do not plug your two upstream cables into the two ports labelled on the RAX120 as "Aggregate".
Instead, plug one into "WAN/Internet" and the other into Port 1 (one of the two labelled 'Aggregate')
- Christian_RJul 09, 2020NETGEAR Employee Retired
Hello RMDEQ,
Thanks for updating your post as it may help others in the future.Regards,
Christian
- RMDEQJul 17, 2020Star
Last week, I discovered another quirk. Or, maybe to folks doing networking it makes total sense and I'm the one with the quirk.
For reasons that are too long winded to get into, I had to change the RAX120 from being a DHCP server and Router into just being a "Wireless AP" (which I also learned is very different from a "bridge"; my last wifi router was a "bridge" for the same long-winded reason, so I guess the terminology changed since that old wifi router came out)
Guess what? When you change it from Router to Wireless AP, the LA ports MOVE!
To do LA with a RAX120 that is a router, use the WAN Port and Port 1.
To do LA with a RAX120 that is a wireless access point, use Port 1 and Port 2.
