HiredGuns
Mar 31, 2023Aspirant
Nighthawk AX12 RAX120v2 firmware: v1.2.8.40 dropping connection
RAX120v2 (serial start with 6K0) constantly (at least once a day) drops the internet-connection. Wifi devices disconnect, hardwired devices loose internet connection. Both lights on top of the router...
- Mar 31, 2023
Here is a link to the latest beta firmware you may want to try it and see if it fixes your issue. https://ntgr.my.salesforce.com/sfc/p/#300000000xsV/a/8b000000lpfE/ewZuT7whqirNo5U_QG.WfrQU.h0pa5dqpbB3qz_Qi3o
Mar 31, 2023Guru - Experienced User
I recommend a factory reset and setup from scratch AFTER applying this FW. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- HiredGunsMar 31, 2023Aspirant
Yep, read that on the forum the other day and tried it. Looked good for a few days and then it all started again
- FURRYe38Mar 31, 2023Guru - Experienced User
Did you do the factory reset as well?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?What devices do you have connected to the router?
Yes
I think it's a Genexis bridge, but I had no problems with a different router.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.I used the LAN cable that came with the Nighthawk.
Auto, and several different channels, and only 2,4 or only 5Ghs
No wifi near by.What devices do you have connected to the router?
2 laptops, 2 smartphones, xbox, satellite receiver, windows mediacenter, TV, Pioneer receiver, 2 printers, Play-Fi speakers, BBQ.
