HiredGuns
Mar 31, 2023Aspirant
Nighthawk AX12 RAX120v2 firmware: v1.2.8.40 dropping connection
RAX120v2 (serial start with 6K0) constantly (at least once a day) drops the internet-connection. Wifi devices disconnect, hardwired devices loose internet connection. Both lights on top of the router...
- Mar 31, 2023
Here is a link to the latest beta firmware you may want to try it and see if it fixes your issue. https://ntgr.my.salesforce.com/sfc/p/#300000000xsV/a/8b000000lpfE/ewZuT7whqirNo5U_QG.WfrQU.h0pa5dqpbB3qz_Qi3o
Mar 31, 2023Guru - Experienced User
I recommend a factory reset and setup from scratch AFTER applying this FW. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
HiredGuns
Yep, read that on the forum the other day and tried it. Looked good for a few days and then it all started again
