larkhillhouse
May 30, 2021Tutor
nighthawk ax12 rax200 and BT tv box problem
hi i have a BT TV box and i have bt sport as part of package. had no problem watching sport channels untill i fitted this ax12. all other internet services are working on the box no problem and if...
- Jun 18, 2021
so set wan setting in AX12 to BT setting and now all working!!!!
thanks for everyones help
thehypnootoad
May 31, 2021Luminary
Included screenshot cant rWaember if igmp proxy needs to be unticked or ticked try both but enable that bt Support igmp proxy .... log into router normally 192.168.1.1 and enter password credentials - advanced - setup - wansetup.
larkhillhouse
Jun 01, 2021Tutor
yes already tried that.
when i disable "disable igmp" and tick the BT box internet stops working completly!
and can't have both ticked at same time.
