larkhillhouse
May 30, 2021Tutor
nighthawk ax12 rax200 and BT tv box problem
hi i have a BT TV box and i have bt sport as part of package. had no problem watching sport channels untill i fitted this ax12. all other internet services are working on the box no problem and if...
- Jun 18, 2021
so set wan setting in AX12 to BT setting and now all working!!!!
thanks for everyones help
larkhillhouse
Jun 01, 2021Tutor
yes already tried that.
when i disable "disable igmp" and tick the BT box internet stops working completly!
and can't have both ticked at same time.
thehypnootoad
Jun 01, 2021Luminary
What modem are you using?
- larkhillhouseJun 01, 2021Tutor
Draytek vigor 130
- thehypnootoadJun 02, 2021LuminaryFrom what Ive seen on BT community you need to do this https://www.draytek.co.uk/support/guides/kb-vigor-130-bridge
- thehypnootoadJun 02, 2021LuminaryThis is the forum https://community.bt.com/t5/Home-setup-Wi-Fi-network/Unable-to-stream-BT-TV-Internet-channels-with-Vigor300-VDSL/m-p/1896387#M156932
