larkhillhouse
May 30, 2021Tutor
nighthawk ax12 rax200 and BT tv box problem
hi i have a BT TV box and i have bt sport as part of package. had no problem watching sport channels untill i fitted this ax12. all other internet services are working on the box no problem and if...
- Jun 18, 2021
so set wan setting in AX12 to BT setting and now all working!!!!
thanks for everyones help
thehypnootoad
Jun 01, 2021Luminary
What modem are you using?
larkhillhouse
Jun 01, 2021Tutor
Draytek vigor 130
- thehypnootoadJun 02, 2021LuminaryFrom what Ive seen on BT community you need to do this https://www.draytek.co.uk/support/guides/kb-vigor-130-bridge
- thehypnootoadJun 02, 2021LuminaryThis is the forum https://community.bt.com/t5/Home-setup-Wi-Fi-network/Unable-to-stream-BT-TV-Internet-channels-with-Vigor300-VDSL/m-p/1896387#M156932
- larkhillhouseJun 18, 2021Tutor
sorry not been back to you guys.
so just tried the vigor130 fix you came up with.
do this rebooted all devises and no joy.
stillsame problem on bt box!!!
