abc888
Jul 18, 2020Aspirant
Nighthawk ax12 rax200 and VPN installation
Hi there, have an existing ExpressVPN subscription and would like to install it on my router. Can it be done for this parricular router? Thanks
michaelkenward
Jul 19, 2020Guru - Experienced User
Have you asked ExpressVPN? It is more likely to have a database if compatible devices.
Or try this:
Search - NETGEAR Communities – ExpressVPN
