Oliver4550
Apr 01, 2023Aspirant
Nighthawk Ax12 rebootin
My Nighthawk Ax12 Rax 120 is always restarting something like 4 or 5 times when I am at home. The firmware is updated. I tried to go back to factory setup but doesnt change anything.
Apr 01, 2023Guru - Experienced User
You might try the beta firmware from this post:
jvillasenor7
Apr 03, 2023Tutor
Hi plemans - Has there been any positive feedback related to the beta firmware? I noticed that my router status doesn't populate CPU loads and other information anymore. I know it's beta and I'm willing to try anything at this point. The performance is a step above my older router... just wish it was stable.
Thanks,
- FURRYe38Apr 03, 2023Guru - Experienced User
I've got lots of feedback from users in PMs after they got the beta that there RAX stop rebooting. Yes there is some items missing from the debug page however that should return when NG releases next FW version. No idea when that will be though.
- jvillasenor7Apr 04, 2023Tutor
I've installed the beta firmware since yesterday and I'm happy to say that it hasn't rebooted yet. I'll continue to monitor and share my experience. Would be good if others posted on their experiences with beta .43-rc! Thanks again for all your contributions.
- FURRYe38Apr 04, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
