Oliver4550
Apr 01, 2023Aspirant
Nighthawk Ax12 rebootin
My Nighthawk Ax12 Rax 120 is always restarting something like 4 or 5 times when I am at home. The firmware is updated. I tried to go back to factory setup but doesnt change anything.
Apr 01, 2023Guru - Experienced User
You might try the beta firmware from this post:
Oliver4550
Apr 04, 2023Aspirant
I will try this BETA during the week-end. I will close the thread if it's solved the problem.
- FURRYe38Apr 05, 2023Guru - Experienced User
đ
