pbgflorida
Apr 23, 2019Aspirant
NightHawk AX12 support USB 3.1 Gen 2 ??
This system support 3.1 gen1 or 2?
schumaku
Apr 23, 2019Guru - Experienced User
The RAX120 has two USB 3.0/3.1 Gen 1 Type-A ports.
- pbgfloridaApr 23, 2019Aspirant
Thanks for the info. I try asking via chat and they told me 3.0 only
but looking at the specs I can see that support 5gbs.
- schumakuApr 23, 2019Guru - Experienced User
The USB 3.0 designation is formally replaced by the USB 3.1 Gen 1 designation (not sure why Netgear does stick with the old one) - it allows indeed 5 Gbit/s.
