TRoundy
Aug 15, 2022Tutor
Nighthawk AX12 wifi draining batteries
I have been having issues with my Nighthawk AX12 router draining the battery of my Nest thermostat. Google Nest tech support is worthless. It seems that something about this router is causing bat...
TRoundy
Aug 17, 2022Tutor
Google tech support said that the issue is with the router (RAX120). The Nest works fine and the battery stays charged as long as it isn't connected to wifi. The wifi signal strength is good to excellent.
I need to know what router settings will work with the Nest.
michaelkenward
Aug 17, 2022Guru - Experienced User
Google search disagrees with Google tech.
draining battery nest thermostat - Google Search
Did you follow any of the many links?
Anything there that you disagree with?
By definition, Google tech will blame anyone and everyone else. Netgear tech will respond accordngly. "Pass the buck" is part of the job description for tech support.
The skill is in ignoring that stuff and doing a bit of research.
A few pointers there.
- TRoundyAug 19, 2022Tutor
Yes, I followed all the Nest pointers other than adding a c wire. The Nest battery holds a charge as long as it isn't connected to wifi.
I've had a Nest for years (with same connection) for years and never had an issue until 2021. I bought a new Nest thinking that was the issue but it wasn't. New one did the same thing. I tried to get the point across to google that the issue is between some Netgear routers (I am not the only one having issues) and the Nest but they choose to ignore me.
- FURRYe38Aug 19, 2022Guru - Experienced User
Does disabling Smart Connect change the behavior?
Try setting manual channel 1 and 40.
