Brillstone
Jun 26, 2020Aspirant
Nighthawk AX12
have a problem with the new router, when to use VPN and FTP? Has opened ports for ftp and also started the VPn according to netgear's software. When I try, all ports are closed and VPN does not wor...
Christian_R
Jul 01, 2020NETGEAR Employee Retired
Hi Brillstone,
I would suggest contacting our support team to assist with your setup.
https://www.netgear.com/support/default.aspx
Christian
Brillstone
Jul 01, 2020Aspirant
It works now, it was my isp fiber switch that was the problem
Thanks
