Th3-0n3
Dec 06, 2019Tutor
Nighthawk ax120 low wifi speed when i disable QoS any help?
guys I just got my Nighthawk ax120 to replace a nighthawk r7800 that was falling on me. When i Do the speed test on my pp that is connected by ethernet cable to the router I get almost the full gig o...
Falcon3856
May 09, 2020Aspirant
Hi,
I am having the same issue.
What was the solution for this?
Thanks for your help
Th3-0n3
May 26, 2020Tutor
sorry I ended up just leaving the thing enable. since I had school work to do.
