JRamirez1996
Nov 05, 2021Follower
Nighthawk AX1800 RAX10 Remote Management
Hello, I am a technical support representative for an ISP and I assisted a customer in setting up their new Nighthawk AX1800 RAX10 today. Everything went smoothly with configuration and they ...
Nov 05, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
