t10bender
Dec 04, 2022Aspirant
Nighthawk AX1800 (RAX10) wifi router
My current set up: Nighthawk AX1800 (RAX10) wifi router, connected to a Netgear wifi cable modem. If I want to add the Mesh 6 system, do i need to: replace the Mesh 6 router with the existing RAX10 ...
Dec 04, 2022Guru - Experienced User
How many satellites do you want?
Reason I ask is if you're only needing one, they make mesh extenders that work well. but if you're needing more than 1, its better to switch to a full mesh system.
How big is your home?
You put you have a RAX10 and a cable modem/router device. What cable modem/router is it?
