t10bender
Dec 04, 2022Aspirant
Nighthawk AX1800 (RAX10) wifi router
My current set up: Nighthawk AX1800 (RAX10) wifi router, connected to a Netgear wifi cable modem. If I want to add the Mesh 6 system, do i need to: replace the Mesh 6 router with the existing RAX10 ...
t10bender
The cable modem is Netgear. The Nighthawk AX1800 router wifi is hooked to it.
Since my post, I ended up connecting the Mesh Router to the Nighthawk wifi router. And created a separate wifi system for the house. Long work around. However, it works......
I want to add one more satellite. I add, I bought 2 of the MK62 box systems from Sam's.
Soooo......
as noted above, I have a mesh router system set up, and working. Now I'm trying to add the other satellite, that I took from the other 2-piece system. Hence, I will not use the other router except for a doorstop.
Now I cannot get the additional satellite, from the other box, to sync up with my current 2 pc system????
michaelkenward
Dec 05, 2022Guru - Experienced User
As plemans asks, which cable modem?
Which Mesh router? An Orbi?
Are the MS60 satellites compatible with whatever it is? They are designed for the MR60 router.
You can just slap together a random selection of routers and satellites, especially in Mesh systems, which rely on coordinated communication between routers and satellites.
Or an access point?
- plemansDec 05, 2022Guru - Experienced User
this guide goes over syncing the satellite to the router.
https://kb.netgear.com/000061554/How-do-I-install-my-NETGEAR-Nighthawk-Mesh-WiFi-6-products
- t10benderDec 05, 2022Aspirant
So here's what I have:
Netgear Cable Modem
Nighthawk AX1800 RAX10 wifi router
I added an AX1800 MK62 Mesh Router / satellite
I want to add another satellite. So I bought another MK62 2 pack, as it was cheaper than just buying one satellite.
- I want to connect the satellite from that box set to the already put in service MK62 Router. I will bag the extra router for another day.
- michaelkenwardDec 06, 2022Guru - Experienced User
Netgear Cable Modem
....Sigh.
plemans wrote:
You put you have a RAX10 and a cable modem/router device. What cable modem/router is it?
- t10benderDec 14, 2022Aspirant
CM1000-100NAS
